#43567 - 07/02/11 01:25 AM Internal Flanges for vessel
Shabeer Offline
Loc: india
Hi All,
I have a question related to internals on one of the vessel which I designed.
The vessels rating is 150 # and there is a 2" pipe (internal pipe) connecting two nozzles inside the vessel. As a process requirement a high pressure gas will be passed inside this pipe. By looking into the design condition of the gas passing in, i found that it falls under 900#. Hence i decided the nozzle to have 900#. My problem is that, if i provide break flanges for this internal pipe......can I go for a plate flange or should i go for a B16.5 flange?
If i am opting to go for plate flange, then how can i justify my client that its good enough to handle the dissimilar pressure?
SHARE YOUR THOUGHTS
#43634 - 07/06/11 01:07 PM Re: Internal Flanges for vessel [Re: Shabeer]
asd23789 Offline
Hello Shabeer,
if you go for a plate flange ,design it with the help of appendix 2 for both internal as well as external pressure ,which is the inside pressure of the vessel.
Also there is a clause in 2-11 in appendix 2 of ASME section VIII Div:01 which states that
[/b](b) When flanges are subject at different times during
operation to external or internal pressure, the design shall
satisfy the external pressure design requirements given in
(a) above and the internal pressure design requirements
given elsewhere in this Appendix.[b]
clause says "Different Times" ???
Hope this helps
ASD23789
(Beginner)
#43800 - 07/17/11 02:16 AM Re: Internal Flanges for vessel [Re: Shabeer]
vishaltailor Offline
Loc: Gujarat, india
Dear Shabeen
as per our understanding, your concern is about flange material made from either forging or plate. pl. refer, Table 2-1.1 pressure-temperature rating for group 1.1 materail, both materail i.e forging & plate is acceptable as per B16.5(2003).
Thanking you & with regards
Vishal Tailor
0 registered (), 40 Guests and 1 Spider online.
March
danb 6
Tyler_Magliolo 3
Borzki 1
Matt.Worland 1
shamaliabhavin 1
