pipingdesignonline.com
#40306 - 01/19/11 08:13 PM need help to generate isometric
vijay4friends Offline
Loc: singapore
hello,
i need ur help to generate the isometric in cadworx.
the situation is i modeled a whole plant in cadworx and while try to generate the isometric i got a reply saying
Only components drawn with the ISOGEN interface active are allowed..."
"Command: _ISOGENOUT
Error reading isometric directory..."
Enter an option [Line number/Select components] <Select components>: S
Select objects: 2 found, 1 group
Select objects: 2 found (2 duplicate), 1 group, 2 total
Select objects: Specify opposite corner: 6 found, 3 groups, 8 total
Select objects: Specify opposite corner: 4 found (4 duplicate), 2 groups, 8
total
Select objects: Specify opposite corner: 4 found (2 duplicate), 2 groups, 10
total
Select objects:
Component not ISOGEN enabled [1]: REDUCER, CONC S/STD, ASTM A-234 GR WPB
Coordinates for component [1]: -52097.8921,73655.7477,1274.9663
Component not ISOGEN enabled [2]: ELL, 90%D LR S/STD, ASTM A-234 GR WPB
Coordinates for component [2]: -51881.9921,73655.7477,1274.9663
Component not ISOGEN enabled [3]: ELL, 90%D LR S/STD, ASTM A-234 GR WPB
Coordinates for component [3]: -51881.9921,73503.3477,1274.9663
Component not ISOGEN enabled [4]: PIPE, S/STD SMLS, ASTM A-106 GR B
Coordinates for component [4]: -51881.9921,73503.3477,1027.0000
Component not ISOGEN enabled [5]: PIPE, S/STD SMLS, ASTM A-106 GR B
Coordinates for component [5]: -55230.3541,73655.7477,1274.9663
Could NOT process 5 component(s) due to permissions failure...
No components were written to file..."
like this?
Thanks,
Best Regards,
Vijay.
#40332 - 01/20/11 09:32 AM Re: need help to generate isometric [Re: vijay4friends]
Mods, this probably belongs in the ISOGEN sub-forum.
As its says, components must be drawn with Plant Professional for them to work with ISOGEN. Those components must have be drawn with Plant Basic.
#40592 - 01/31/11 03:23 PM Re: need help to generate isometric [Re: dgorsman]
clarkrj Offline
There is a thread in the ISOGEN forum that covers this. The drawing needs to be converted to ISGGEN ready with the help of technical support. I will say this is a very easy task and goes quickly, even for several models.
Clark R. Johnson
Enerflex
0 registered (), 44 Guests and 1 Spider online.
