Can you give me a little help so I can get the set up back to what is was before with the input on the left and the graphics on the right.
You should be able to grab the title bar of the graphics window and just drag it to your other monitor.
when you try and save it to use in a report it is well below average compared to 4.5. Is there any settings which can improve the quality of the the graphics stored as a bitmap, jpeg etc.
BMP is a better format (from a quality view point) to save than JPG. There is no reason the BMP files generated should vary between versions, the same can be said about JPG files.
One thing you may try, just incase something erroneous crept into the mix, is to delete the PREPIP key from the Registry. Start REGEDIT and navigate to:
"HKEY_CURRENT_USER\Software\COADE, Inc.\CAESAR II\5.10"
From here, delete the entire "PREPIP" key. If that doesn't help, send an example BMP from both versions to (David Little) dlittle@coade.com.
