Yep, this is one of the basic techniques for coping with the problem. Congratulations on inventing it on your own!
You need to be aware of how constructable what you are doing is. If, for example, you have the force on your pivot point changing sign in different load cases, you need to make the pivot point a gapped restraint to account for real world construction limitations. You also need to coordinate with structural to make sure your rack can withstand the loads you impose, although these will likely be pretty small.
CraigB
