#76435 - 05/13/22 09:48 AM Custom Spec Information(ie. Valve Trim or Operator)
Kimpten Offline
I have a client that is wanting as much information as possible to be added to the long description of several components. I will use the valve though as an example. Is there a way to add a custom table for the various valve trims and then reference one of those options with a format code instead of having to hard type that information over and over again. Same situation on other pieces of a valve like the operator type.
Thanks,
#76437 - 05/16/22 08:13 AM Re: Custom Spec Information(ie. Valve Trim or Operator) [Re: Kimpten]
Index and Dat Codes should do what you are after, but it needs to be a full long description based on the index code. If you are looking to build a long description based on many different fields, then you can add the fields to one of the required tables like materials. Then as you build your long description, you point to that table and pull in the data. I haven't found a way to create a custom table for this and we just use one of plant's required tables.
#76443 - 05/16/22 11:00 PM Re: Custom Spec Information(ie. Valve Trim or Operator) [Re: Kimpten]
Have you looked at using Custom Data ?
#76445 - 05/17/22 07:11 AM Re: Custom Spec Information(ie. Valve Trim or Operator) [Re: Kimpten]
Kimpten Offline
I will look into the suggestions here. We looked at just adding Custom Data on the data table for valve. However, it was then an issue with inside the same spec, we would be linking to that same data table and needing two different operators and valve trims.
I am still trying to learn what all I can do inside the specification editor to streamline the process. So it will take me some time to learn how to implement the suggestions given.
Thanks,
#76449 - 05/17/22 11:41 PM Re: Custom Spec Information(ie. Valve Trim or Operator) [Re: Kimpten]
I believe the catalog level custom data can be set as a default, but can be overidden in the model with different data
0 registered (), 27 Guests and 0 Spiders online.
June
26 27 28 29 30
12004 Members
16838 Topics
Richard Ay 10
danb 7
Van Ha 7
Vanman 7
Michael_Fletcher 6
