#75839 - 09/02/21 10:57 AM BOM Export - Bolt Formatting
SaturnV Offline
Loc: Lone Star State
Does the BomBoltControl setting affect the Export BOM? I know it impacts Isogen. I'm trying to get the bolts formatting on the Excel output to have the bolt set(for example, (8)) as it appears in the long description in the model.
SaturnV
#75842 - 09/02/21 11:38 PM Re: BOM Export - Bolt Formatting [Re: SaturnV]
Bolt Control for the non Isogen BOM moved to the BOM Setup.
Edited by Vanman (09/02/21 11:39 PM)
#75844 - 09/03/21 11:56 AM Re: BOM Export - Bolt Formatting [Re: Vanman]
SaturnV Offline
Thanks Vanman. I do have a couple of follow-up questions.
We are running 2019 SP3. Do you know when that level of control went there? Was there a way of controlling that prior to the release you are running?
SaturnV
#75850 - 09/05/21 11:55 PM Re: BOM Export - Bolt Formatting [Re: SaturnV]
For 2019 its in the same location.
Older versions used the BomBoltControl for both Isogen and the regular BOM.
#75856 - 09/08/21 07:38 AM Re: BOM Export - Bolt Formatting [Re: SaturnV]
SaturnV Offline
I did a test with 4 different cfg files each having a different BomBoltControl value: 0 1 2 and 3. I ran four different BOM reports with an apply and close of each config file and got the same results.
The Export BOM report has:
5/8" STUD BOLTS CL 600 RF ASTM A193 GR B7 ZINC OR CADMIUM PLATED W2 ASTM A194 Gr 2H HEAVY HEX NUTS ZINC OR CADMIUM PLATED
Isogen description (the preferred style) output has:
(8) STUD BOLTS CL 600 RF ASTM A193 GR B7 ZINC OR CADMIUM PLATED W2 ASTM A194 Gr 2H HEAVY HEX NUTS ZINC OR CADMIUM PLATED (4 1/4" LG)
Looking for hints on how to get where I would like to be on this.
SaturnV
#75857 - 09/08/21 08:08 AM Re: BOM Export - Bolt Formatting [Re: SaturnV]
2019 Bolt Control for Export BOM in the picture below.
I believe pre 2019 versions BOMBoltControl was used for both the Export BOM and Isogen.
In the newer version BOMBoltControl has been renamed to IsogenBoltControl.
#75859 - 09/08/21 01:55 PM Re: BOM Export - Bolt Formatting [Re: SaturnV]
SaturnV Offline
Vanman,
The menu I have does not look like that. What does the [Pipe BOM] cfg file look like in that area?
SaturnV
#75860 - 09/09/21 12:55 AM Re: BOM Export - Bolt Formatting [Re: SaturnV]
What Version are you using ? If your menu is not looking like that possibly you are using 2018 or earlier ?
With 2019 the BOM Settings were moved to XML file contained in the \system Directory.
#75861 - 09/09/21 08:04 AM Re: BOM Export - Bolt Formatting [Re: SaturnV]
SaturnV Offline
Thank you Vanman. I found the .xml file. This is what it looks like.
Description: CADWorx 2019 SP3 Imperial.xml
#75864 - 09/09/21 11:02 PM Re: BOM Export - Bolt Formatting [Re: SaturnV]
If you run the BOMSETUP command, this will bring up the menus as in the previous posts. If you are going to edit the XML directly, I would recommend making a backup.
#75865 - 09/13/21 07:56 AM Re: BOM Export - Bolt Formatting [Re: Vanman]
SaturnV Offline
This does not look like this on my PC. When I get some time I may do a reinstall on my PC.
SaturnV
#75866 - 09/13/21 08:07 AM Re: BOM Export - Bolt Formatting [Re: SaturnV]
SaturnV
Should probably hold off on that. There's no way a "bad install" would have that result.
How are you calling the BOM setup?
#75867 - 09/13/21 11:27 AM Re: BOM Export - Bolt Formatting [Re: dgorsman]
SaturnV Offline
SaturnV
Either via the button or the "BOMSETUP" command.
SaturnV
#75869 - 09/14/21 10:57 PM Re: BOM Export - Bolt Formatting [Re: SaturnV]
What does the BOMSETUP dialog look like on your installation ?
#75870 - 09/15/21 08:38 AM Re: BOM Export - Bolt Formatting [Re: Vanman]
SaturnV Offline
This is what is looks like Setup->Modify
SaturnV
#75873 - 09/15/21 11:29 PM Re: BOM Export - Bolt Formatting [Re: SaturnV]
Try BOMSETUP > Settings.
