#75343 - 01/20/21 02:27 PM Same model - Different desing codes
Stack_cl Offline
Loc: Santiago Chile
Hi,
I am working in a model with Steel and FRP pipes, we are using ASME B31.3 for the steel pipes, and ISO 14692 por FRP.
How can I get the report "Code Compliance" per code?
When I see the report the ratio%, code stress, axial stress, etc is listed for the biggest of both codes wherever the filter I do, and I want to see it separated.
Could you help me please?
Thank you
#75347 - 01/21/21 05:55 PM Re: Same model - Different desing codes [Re: Stack_cl]
I know CAESAR has issues with at least some piping code combinations - e.g. B31.3/B31.8.
But hopefully you organized your CAESAR file nodes in such a way you can identify by the number what the materials are. E.G. nodes 1-4000 = steel, nodes 4010+ = FRP.
Then you can specify in the output processor to filter based on nodes 4010+ or <4010. It requires two different reports, however.
#75349 - 01/22/21 04:49 AM Re: Same model - Different desing codes [Re: Stack_cl]
Stack_cl Offline
Loc: Santiago Chile
Hi, yes I know the different stress reports, there is a "Streeses mutlicode", also we have the "stresses" this one generate different sheets per case and per code, thats right... but I want a report that shows the legend "code compliance evaluation passed" per code in a sumamry o cases....
0 registered (), 44 Guests and 0 Spiders online.
