Rather than using the Nozzle Type: Standard. Have a look at using the LWN from the FVC Nozzle Type. Here you can set it up to use catalog dimensions or Actual dimensions (your dimensions).
I have had better success with these components rather than the standard which has limitations.
If I remember correctly, I think there was an issue where CADWorx had applied Nut Stop and Nut Relief dimensions to this item that needed to be tweeked in the master catalog as these do requirements do not apply to LWN's.
Edited by Hal Perison (01/19/21 01:01 PM)
