pipingdesignonline.com
#74788 - 06/18/20 12:09 PM bent strcutrual components
jwood Offline
Loc: Texas
Structural 2019
When I create a PLINE with an arc the materials are split into three parts but I wish to have a single item that I call out as "bent" in the BOM. Single arc is fine by itself. Suggestions?
2020-06-18 13_04_34-Hexagon PPM CADWorx Structure 2019 SP2 - Autodesk AutoCAD 2019 - [Drawing1.dwg].png
#74819 - 07/01/20 09:33 AM Re: bent strcutrual components [Re: jwood]
It looks like Structure draws 3 separate pieces since they are separate, it won't consolidate in the BOM.
#74821 - 07/02/20 12:16 AM Re: bent strcutrual components [Re: jwood]
What you could do is model this as an extruded 3d solid or similar and then use the Structure generic attach tools. Not ideal I know, but this will resolve your BOM issues.
#74823 - 07/02/20 10:08 AM Re: bent strcutrual components [Re: Vanman]
Byron Offline
Loc: LA, USA
what is Structure generic attach tool
#74824 - 07/02/20 11:25 PM Re: bent strcutrual components [Re: jwood]
This allows you to add data to any 3D Object in the model.
https://hexagonppm.fluidtopics.net/reader/5c7jKFeZbnbXObM~dAShug/KqFGEvNUw2pYjAKCifuiOQ
#74832 - 07/06/20 01:40 PM Re: bent strcutrual components [Re: jwood]
Yeah, Generic Attach is wonderful for those oddball components. It would be greater if you could put pre-made descriptions into a spec so they don't have to be typed in manually every time.
#76351 - 03/31/22 03:52 PM Re: bent strcutrual components [Re: Vanman]
Hal Perison Offline
Loc: Canada
Nice, but I have found that within CADWorx Structure, Generic Attach items do not extract to a BOM. (I can't say about any 3D solid elements, but have experienced this lack of BOM in CADWorx Structure elements converted to a Block and Generic information attached to the block)
Maybe, I am missing something here.
Edited by Hal Perison (03/31/22 03:55 PM)
#76352 - 03/31/22 11:09 PM Re: bent strcutrual components [Re: jwood]
There seems to be a limitation with Generic on Blocks. I see if I can make some tests on the Beta.
#76353 - 04/01/22 08:23 AM Re: bent strcutrual components [Re: Hal Perison]
'New feature' in the past you could get Generic attach from pipe and structure items into a BOM, but last I tested it was still broken.
Moderator:  AimeeFerguson
0 registered (), 65 Guests and 0 Spiders online.
