#74147 - 11/13/19 08:25 AM Cadworx Display flickering blinking when attaching xref's?
treysoucie Offline
Loc: New England & Houston
This appears to only happen when in cadworx. when operating plain jane autocad i cant replicate it. when i go to attach xrefs the display will enter a loop of flickering that can go on for many minutes.
https://youtu.be/vnohtN_2dOs
https://youtu.be/9vh4QiDMxtg
Edited by treysoucie (11/13/19 08:38 AM)
Design/Drafting Supervisor
TreySoucie@sbcglobal.net
#74150 - 11/13/19 12:31 PM Re: Cadworx Display flickering blinking when attaching xref's? [Re: treysoucie]
treysoucie Offline
this appears to only be happening when i have the cadworx palettes loaded
#74181 - 11/18/19 09:21 AM Re: Cadworx Display flickering blinking when attaching xref's? [Re: treysoucie]
Hey Trey,
If you have more than one drawing open this issue could happen. Try and close out all other files and see if the issue continues.
#74183 - 11/18/19 11:38 AM Re: Cadworx Display flickering blinking when attaching xref's? [Re: treysoucie]
treysoucie Offline
still seems to be happening even with just one drawing open
#74192 - 11/19/19 12:18 PM Re: Cadworx Display flickering blinking when attaching xref's? [Re: treysoucie]
Ouch, maybe check to see if you are running the latest.
#74200 - 11/20/19 02:38 PM Re: Cadworx Display flickering blinking when attaching xref's? [Re: treysoucie]
rchiasson Offline
Loc: Houston, TX
What version of CADWorx are you running? If it is 2019, you likely need to have the latest service pack installed.
"Try not to become a man of success, but rather to become a man of value."
#74458 - 02/19/20 03:16 PM Re: Cadworx Display flickering blinking when attaching xref's? [Re: treysoucie]
Zaxatac Offline
Loc: Texas, USA
Is it CADWorx 2018? If so, this patch resolves the issue along with the Civil 3D Object Enabler not loading in CADWorx Plant. Here is the link, the fix only works on CADWorx 2018 on AutoCAD 2018. https://www.dropbox.com/s/ycslkb256u0w5kh/CADWorx2018_C3DOE_fix.exe?dl=0
