In the US the g factor is calculated per Chapter 13 of ASCE 7. It basically takes the mapped Ss value for your region and adjusts it based on factors associated with piping.
This is in contrast to dynamic analysis, where you'd typically enter the whole spectrum response graph so you can see how your systems responds.
If you search seismic G factor you'll get other posts discussing the seismic wizard built into Caesar.
