#72715 - 01/16/19 02:27 AM expansion joint weight
vermaccio Offline
when i create an expansion joint i set data in E_J windows (axial stiff, trans stiff, bending stiff, torsion stiff, effective id).
1)
where do i add the EJ weight?
2)
if i don't insert any weight, the EJ weight is calculated as the weight of a pipe having same lenght?
#72718 - 01/16/19 08:28 AM Re: expansion joint weight [Re: vermaccio]
The expansion joint element, in CAESAR II, is weightless.
I suggest you apply added assembly weight to the (rigid) elements on either end of the joint.
0 registered (), 33 Guests and 2 Spiders online.
