Hi
There is a mismatch for Input Diameter of Exhaust Flange considered in the Input Sheet and the NEMA Calculation in Caesar -II 2017, Ver.9.00.00.5902 (Build 170419)
For example, referring to the attached word file , Input Nominal Diameter is 88" whereas the same is considered as 72" by Caesar.
Equivalent Diameter calculated is also incorrect 29.333 instead of 34.3333
This problem was not encountered in Caesar 6.1 when we counter-checked in the same.
both files are attached for your ready reference
Please help to solve the same
NEMA NOZZLE VERSION 6.1.pdf (202 downloads)NEMA NOZZLE VERSION 9.0.pdf (429 downloads)
astressguy
