#67969 - 12/22/16 02:11 PM
How can I write simple pcf file
Hi how can I write simple pcf file. Pipe of 6 inch starting 0,0,0 to 0,500,0 In mm and schedule 40 thk Anchor at 0,0,0 Bend at 0,500,0 and tee. And how can I run in Caesar 7.0
Pls advice me step by step.
Thanks in advance, Regards, Sridhar
#67987 - 12/24/16 11:46 AM
Re: How can I write simple pcf file
[Re: sridhar]
If any pcf file run. Always gives error and terminate. Can anyone provide working pcf file please.
#67997 - 12/26/16 01:48 PM
[Re: sridhar]
Richard ay or Dave can you pls Support
#68004 - 12/27/16 06:46 AM
[Re: sridhar]
Loc: Houston, Tx, USA
When you generate Isometrics in CAESAR II, you will see a pcf generated. That is good for geometry and is not so detailed as one generated by CAD software. But, it should help.
Best Regards, Mandeep Singh CADWorx & Analysis Solutions Hexagon PPM
#68007 - 12/27/16 11:00 AM
[Re: sridhar]
Thanks Mandeep.
But I do not want to generate stress isometrics. I want to import pcf file in Caesar so that I need not model 3d pipe geometry from solidworks software. There is import pcf file in Caesar. And pcf file can be exported from solidworks.
When I done this exercise it run a while and then program terminated. Hence wanted to see simple pcf file which can able to run so that I can check if something wrong and wrong in file.
#68036 - 01/03/17 09:22 AM
[Re: sridhar]
I suggest you dump out a pcf created by a small CAESAR II model and compare that to the product of Solidworks. (Click on "Generate Stress Isometrics" on the Main Menu, then take a look at the pcf created.) This comparison should illustrate the extent of the required modification.
#68109 - 01/16/17 06:09 AM
[Re: sridhar]
You may also use the pcf files that comes with Caesar. See inside Examples folder.
#68116 - 01/17/17 08:27 AM
[Re: sridhar]
Be careful with PCF files. The files generated by CAD systems are suitable for import into CAESAR II, so you don't have to manually code the geometry. Depending on which CAD system generated the PCF, there may be additional information transferred (insulation, temperature, pressure, etc).
The PCF generated by CAESAR II is intended to drive Isogen and produce a stress-iso. This is not suitable for import back into CAESAR II, this is why we appended "-SISO" to the filename.
#72212 - 09/20/18 11:02 PM
Mill tolerance 12.5%
[Re: sridhar]
Loc: Kazakhstan
Hi Everyone,
I am so sorry that i am writing here for another post/ I am new user, I dont know how to create the new post on site, also new user Caesar II.
Can you tell me please, we are uing Mill tolerance 12.5% for insulated pipes or uninsulated pipes?
material is A333 GR.6
Thanks, Dauren!
#72214 - 09/21/18 08:04 AM
Re: Mill tolerance 12.5%
[Re: sridhar]
Dauren,
Click the "New Topic" link at the top of the forum's main page.
The Mill Tolerance is displayed on the classic piping window on the left side, approximately half way down. It automatically populates, but you can change the value.
#72221 - 09/24/18 04:13 AM
[Re: Michael_Fletcher]
Loc: Kazakhstan
