pipingdesignonline.com
#62306 - 03/06/15 08:11 AM Handrail - ladders cut
Patrizio Offline
Loc: Italy
Hi!
I've designed handarils and ladders using Cadworx steel 2015, can someone kindly explain how can I make openings by removing objects (for ex. pieces of intermediate rails, posts etc.).
I would like to do this without having to explode the objects
Thanks!
Edited by Patrizio (03/06/15 08:17 AM)
DB progetti
Pressure vessels engineering, filtration solutions for Oil & Gas
Italy
#62309 - 03/06/15 09:18 AM Re: Handrail - ladders cut [Re: Patrizio]
You can toggle grouping off. I normally use CTRL + Shift + A. You will be able to move individual rail components. Toggle grouping back on when done.
#62311 - 03/06/15 09:50 AM Re: Handrail - ladders cut [Re: Patrizio]
Patrizio Offline
Loc: Italy
Thank you Vanman, that was exactly what i was looking for
DB progetti
Italy
#74173 - 11/15/19 06:25 AM Re: Handrail - ladders cut [Re: Vanman]
Byron Offline
Loc: LA, USA
Vanman - Is this method good for Structure 2019 - It seems to ungroup but cannot delete the individual member?
Thanks Byron
Edited by Byron (11/15/19 06:27 AM)
#74179 - 11/17/19 10:32 PM Re: Handrail - ladders cut [Re: Patrizio]
For Structure, what you can do is to explode the ladder. You can then edit individual items, but there is no way to combine/group it again so that you can edit it via the palette.
0 registered (), 49 Guests and 1 Spider online.
