#58569 - 04/11/14 12:15 PM API 650 App P shell thickness w/repad
daryljose Offline
Loc: alberta
I am working through the nozzle calculations per App P.2. The tank includes a repad (1/4", same as shell).
My question is does 't' (shell thickness) include this repad ie. 1/2"?
I can see it not being included for somthing like radial deflection or shell rotation, since the repad is only a small part of the tank shell. But if it isn't included at all, I dont see where having a repad or not benefits the calculation, ie. shouldn't the calculation with a repad produce higher allowable loads?
Thanks.
Daryl
#58574 - 04/11/14 07:03 PM Re: API 650 App P shell thickness w/repad [Re: daryljose]
The stiffness curves for "reinforcing on the shell" assume a pad with thickness equal to the shell thickness.
#58711 - 04/22/14 08:29 AM Re: API 650 App P shell thickness w/repad [Re: daryljose]
Jamil Offline
Loc: Saudi Arabia
Dear Mr. Richard,
You are saying that appendix P curves are based on thickness of shell plus pad of same thickness as shell,and There is no need of giving pad thickness??
#58739 - 04/23/14 04:01 PM Re: API 650 App P shell thickness w/repad [Re: daryljose]
Yes, that is the assumption if you select the curves for "reinforcing on the shell". The other set of curves, "reinforcing on the nozzle" assumes no pad is necessary.
Moderator:  Luis Sanjuan
1 registered (Gino2010), 32 Guests and 1 Spider online.
November
26 27 28 29 30
