#48478 - 04/24/12 08:01 AM CADWORX 2012 PLANTMENU ERROR
MKN Offline
Loc: KSA
Dear members,
i've Installed CADWORX 2012 and my AUTOCAD version is 2012. after installation i've restarted my system and then opened cadworx 2012 software, the software opened but the CADWORX plant menu and tools are disappeared. how to enable CADWORX plant menu ad tools.
Thanks in Advance......
#48485 - 04/24/12 08:35 AM Re: CADWORX 2012 PLANTMENU ERROR [Re: MKN]
Run the menubar command and change the value from 0 to 1.
#48490 - 04/24/12 09:59 AM Re: CADWORX 2012 PLANTMENU ERROR [Re: MKN]
And set up and save your workspace - that determines which UI elements (toolbars, Ribbon tab/panels, menus, palettes, etc.) are shown, including the partially-loaded CADWorx content.
#48508 - 04/25/12 01:18 AM Re: CADWORX 2012 PLANTMENU ERROR [Re: MKN]
MKN Offline
Loc: KSA
Dear Vanman,
its not menu bar problem as pe my knowledge. all autocad menu's and tool bars are displayed.
i've installed in other system also but the same problem again
Please suggest how can i solve this problem.
thanks in Advance....
MKN
Design Engineer
#48513 - 04/25/12 07:32 AM Re: CADWORX 2012 PLANTMENU ERROR [Re: MKN]
fenchane Offline
Loc: Shanghai,china
Originally Posted By: MKN
Dear members,
oh shit, I also meet this case,
what is your date of your CadWorx's relase date? I think you software is same with mine, it is also was released at Dec.15,2011,
This package is some problem, i try manytimes also at different PC, the result is same, Cadworx2012 call not loading the *.arx file. is it right?
Edited by fenchane (04/25/12 07:47 AM)
#48532 - 04/26/12 06:49 AM Re: CADWORX 2012 PLANTMENU ERROR [Re: MKN]
MattCB Offline
Loc: Wichita, KS
two commands: LOADMENUPLANT & LOADMENUEQUIP
#48535 - 04/26/12 08:15 AM Re: CADWORX 2012 PLANTMENU ERROR [Re: MKN]
Greg Silva Offline
Loc: Owasso, OK
Also something to try if IT installed the software when they were not logged in as you. You may need to go to the CADWorx plant folder and locate the file Setup_Profile_Plant_18_64.exe. Go ahead and double click it to run it. This will create a profile for CADWorx Plant based off of your login. You may need to do this for all your CADWorx programs loaded if they also do not work.
Hope this helps.
C Greg Silva
Owasso Drafting & Design
cgsodd@cox.net
#48558 - 04/28/12 01:33 AM Re: CADWORX 2012 PLANTMENU ERROR [Re: MKN]
MKN Offline
Loc: KSA
Dear Members,
I've solved this Problem my self by changing the Installation path.
But CADWORX 2012 has some bugs like Specification and CAESAR II Conversion.
MKN
Design Engineer
#48605 - 05/02/12 01:18 AM Re: CADWORX 2012 PLANTMENU ERROR [Re: MKN]
CII Conversion works beatifully on 2012. What version of CII are you exporting to ? I think only version 5.20 and 2011 are supported.
0 registered (), 43 Guests and 1 Spider online.
